4 members (Paul Mullen, delwrench, 2-Ton, 1955 1 Series), 70 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#1354040 04/08/2020 4:27 PM
Custom Title
Custom Title
Does anyone have a picture of correct heater hose routing for the 49 trucks? TIA!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
What heater - brand/make & style/type?
Insomniac
Insomniac
Also depends on the engine.
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
Custom Title
Custom Title
My bad.. It's the Chevy deluxe heater with the fancy control valve. Engine is a stovebolt
49 Chevy 3600
65 Chevy K10
What Stovebolt? 194, 216, 235, 261, 292 etc.
β€˜65 Chevy Biscayne (Emily)
β€˜39 Dodge Business Coupe (Clarence)
β€œI fought the law and the law won" now I are a retired one!
Google old online Chevy manuals. There is a listing for 1951 accessories installation manual which shows the set up that I used for my 49 3100 w/216. Figure 100 is were I found the diagram. "chevyoldcarmanualproject.com"
Ed
Custom Title
Custom Title
Stovebolts are only the 216, 235, and 261
49 Chevy 3600
65 Chevy K10
Custom Title
Custom Title
Nailed it! That's exactly what I needed. Thanks!!
49 Chevy 3600
65 Chevy K10
Really? You need to read up on your Chevy history. Now that we’re all stuck at home would be a good time to do some serious studying.Γ°ΕΈβ€ΊΒ
Ex Hall Monitor
Ex Hall Monitor
A little reading on what a Stovebolt engine is.
The term "Stovebolt Engine" is slang terminology, (likely derogatory in nature), so a wide berth can be expected as to what truly constitutes a stovebolt engine.
To me, a stovebolt fastener is flat on top and takes a flat blade screwdriver.
What was the last Chevrolet engine which actually had stovebolts on them?
"Stovebolts are only the 216, 235, and 261"
In addition to what Tiny posted, here is a little more information about The Stovebolt Six - The Cast Iron Wonder 1929-1953 (or, 1929-1963, depending on your definition).
Insomniac
Insomniac
I mentioned the engine since the hoses on the 235 and 261 are different. The 261 has a bypass hose.
Didn't mean to create a fuss.
Gord πŸ‡¨πŸ‡¦
No fuss Gord, just a moment to educate. All is well. laalaa
Originally Posted by Brad Allen
Here are the views for Air-Flow type hook-up (believed original preserved trucks).
Late to the party, but Brad's first photo shows the hoses routed thru thin air to the engine instead of over to the inner fender and held in place by the double clamp in the grooves in the inner fender. The clamp is shown Here. It's the thing that's kind of bird shaped (wings).
[on edit]Hmmm. Looked at the accessory manual listed and they don't show the hoses routed over to the inner fender. ohwell
I would think that would be a better routing to keep the hoses away from most of the engine, but apparently Chevy didn't think it was necessary. I wonder why they put those grooves there (and the double hose clamp).
This is from the 1951 Chevy Accessories installation manual,you may have to click next page a couple of times.
air flow heater
Tim
1951 3100 Chevrolet
This picture is of the type of heater that was in my first 1950 Chevy pickup. You would call that a Recirculating heater, right? No control valve and no fresh air vent.
Professional Novice
Yes, that is a Recirculating Heater.
