5 members (Otto Skorzeny, greenie-reddy, Wayne67vert, 2-Ton, TUTS 59), 132 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
#1354212 04/09/2020 4:19 PM
FIRST off Thank you for any reply on my question. I just put a clutch in my truck FRANKEN so i removed the trans and took the shifter out of the trans to take it out of the way . THE pins in the cone that hold the shifter in place seem to me to be way to loose. Can anybody tell me if they are to be pressed in tight or can they wobble .The hold down clamp that is spring loaded does its job when you press it down to lock the shifter in . If i need to get new pins who may have them online THANKS BJF
Once those pins start wobbling they will wear the holes in the shift tower egg-shaped in a hurry. I've fixed that problem by threading the holes and putting a short bolt in from each side, and grinding the end threads off for a snug fit where the shifter pivots. A Grade 8 bolt will last a long time in an application like that, and if it wears, it's replaceable.
' Offline
SM 420 Shifter Fulcrum Pins
GM part # 590282
https://i.postimg.cc/66GRFRRq/SM-420-Fulcrum-Pins.jpg
Friesen Chevrolet
Sutton, Nebraska
phone : 402 - 773 - 5538
Friesen has ( 70 ) fulcrum pins in stock
Newton Motors
Glasgow , Montana
phone : 406 - 228 - 9326
Newton has ( 37 ) fulcrum pins in stock
The fulcrum pins are a press fit with no wobble .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
THANK YOU AND AS ALWAYS YOU GUY COME THRU, THE BEST INFO BJF
I sent you a PM
