| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | FIRST off Thank you for any reply on my question. I just put a clutch in my truck FRANKEN so i removed the trans and took the shifter out of the trans to take it out of the way . THE pins in the cone that hold the shifter in place seem to me to be way to loose. Can anybody tell me if they are to be pressed in tight or can they wobble .The hold down clamp that is spring loaded does its job when you press it down to lock the shifter in . If i need to get new pins who may have them online THANKS BJF | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Once those pins start wobbling they will wear the holes in the shift tower egg-shaped in a hurry. I've fixed that problem by threading the holes and putting a short bolt in from each side, and grinding the end threads off for a snug fit where the shifter pivots. A Grade 8 bolt will last a long time in an application like that, and if it wears, it's replaceable. Jerry
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | SM 420 Shifter Fulcrum Pins GM part # 590282 https://i.postimg.cc/66GRFRRq/SM-420-Fulcrum-Pins.jpgFriesen Chevrolet Sutton, Nebraska phone : 402 - 773 - 5538 Friesen has ( 70 ) fulcrum pins in stock Newton Motors Glasgow , Montana phone : 406 - 228 - 9326 Newton has ( 37 ) fulcrum pins in stock The fulcrum pins are a press fit with no wobble . George '54 3600 | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | THANK YOU AND AS ALWAYS YOU GUY COME THRU, THE BEST INFO BJF | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | | | |
