6 members (Donf, DoubleB, BillCollins, Wally / Montana, Otto Skorzeny, tclederman), 62 guests, and 2 robots.
Topics128,090
Posts1,056,022
Members48,430
#1353531 04/05/2020 6:36 PM
Hello All,
I'm new to here and had a question about my 53 Chevy pickup that I'm rebuilding, I'm putting my parts back on and working on the clutch/brake pedal assembly.
I'm not sure what this part is called but it's the 2 large washer like spring holders, front & back and also the spring and retaining clip that holds all of this on the clutch and brake pedal on the shaft.
I may be calling it the wring thing when I search but does anyone know what this part is called and who sells them?
Thanks in advance.
Bob
bob53 #1353602 04/06/2020 12:09 AM
Bob,
Section 5, Sheet 2.00 of the 1947-1954 Factory Assembly Manual identify those parts as follows:
Inner Retainer - 3683046, Spring - 3683045, Outer Retainer - 3683047, Pin Lock - 359380.
The pin lock can be obtained from Classic Parts of America ( www.classicparts.com ). They call it a "Huck Brake Anchor Pin Lock Clip 36-52, Item: 71-514, price $1.99
I don't know where you can get the other parts since I re-used mine.
Hope this helps a bit? Good luck!!
Charlie
'51 3100 5-Window (Restomod in progress)
Thanks Charlie,
It sure does help, now I know what they're called at least, I'll go on a search now and see what I can find.
Thanks very much
Bobby
bob53 #1366412 06/25/2020 3:31 PM
Not sure if this is the correct place to ask this, but would anyone on the forum have the used parts that Charlie described ?
Inner Retainer - 3683046, Spring - 3683045, Outer Retainer - 3683047, Pin Lock - 359380 They are all used on the clutch/brake pedal shaft to hold those pedals on.
Thanks for any input.
Bob
bob53 #1366419 06/25/2020 4:32 PM
bob53 - the parts you are looking for will likely have to come from a "donor" truck or maybe you should post those parts in the parts wanted forum if you have not already done so. If you wish, you could contact RPM Classic parts in Albert Lea, MN 888-223-1864 or Mother Trucker Trucks in Tuscon Arizona 520-235-2659 / 520-570-4824 . You could contact Ken Neel in Oklahoma at 918-605-2248, and there's Jerrys Used Parts 816-833-4414 . Also google Mongo's Garage and check with them as well. Hopefully you can find the parts you need. Happy bolting my friend, its a journey sometimes.
Ron - - Dusty53
1954 Chevy 3604
