2 members (baldeagle, Shaffer's1950), 67 guests, and 1 robot.
Topics128,015
Posts1,055,335
Members48,419
#1352960 04/02/2020 9:12 PM
in 1975 i bought a sun scope still have and looks new. the number induction lead is hooped . dont know where to start looking . does anyone have any idea
mikebrou #1352963 04/02/2020 9:21 PM
Sun used to have an equipment maintenance phone hotline with an 800 prefix, but when Snap-On bought the company in the late 1980's I'm pretty sure they stopped, or at least severely cut back on servicing the older equipment. Those machines and test lead sets come up on Ebay pretty often. Try a search there. I was once a regional training director for Sun, just before the big switch to Snap-On took place. My job got cut pretty quickly when that happened!
mikebrou #1353252 04/04/2020 4:38 AM
hello jerry
i thankyou for your time and knowledge.ill start looking at ebay.i bought it new . when i sold shop i decided to keep it for my old cars, now its a old freind but part of the decor in shop as well. i dont know about you, but i miss the years from 65 to about 75 in the trade.we use to have reps drop in regulary they also became freinds. hope you and your family are doing ok during these difficult time. thanks again stay well
mikebrou #1353253 04/04/2020 4:49 AM
my apology jerry. what is proper name for the lead im needing.
mikebrou #1353272 04/04/2020 12:53 PM
Jerry don't bother with nothin "proper"
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
mikebrou #1353290 04/04/2020 2:52 PM
Insomniac
Insomniac
There was a guy on usedcowichan.com selling Sun equipment a few months ago. He might have been in Ladysmith? I can't find his ad now. Maybe you could post a wanted ad?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
mikebrou #1353295 04/04/2020 3:38 PM
There are two inductive pickup leads on most Sun testers- - - - -a chrome-plated one that clamps over the coil wire and a red one that senses a signal from the #1 spark plug wire. Which one do you need? The coil wire lead can also accept an inductive probe that clips over the coil in the distributor cap on a GM HEI distributor. The same basic inductive probe as the #1 plug sensor is used on Sun timing lights.
mikebrou #1353317 04/04/2020 5:59 PM
i need the red one that goes over number spark plug wire. thankyou jerrry
Gord&Fran #1353319 04/04/2020 6:01 PM
thankyou gord i never thought of posting a want ad .i will do that hope all is well with you and family
mikebrou #1353341 04/04/2020 8:21 PM
Is the wire itself, or the clip-on sensor the part that's bad? The wire is nothing but a piece of shielded coax cable like a radio antenna uses. Anybody with a little bit of soldering expertise can make one. All you'd need to do would be to swap the ends that attach to the machine and the probe. I have a Sun scope than is probably never going to be put back into service if it's the sensor that's bad.
mikebrou #1353369 04/04/2020 11:05 PM
Book in my shop library:
hello and thanks again, jerry.
its the sensor number 507-006.it seems simple enough but with ohm meter i can see what is wrong with it.
mikebrou #1354689 04/12/2020 1:32 AM
does any still use scopes, been forever since I have seen one, I was preaty good at setting up carbs using the scope, RPM and a CO machine
woof359 Family 1952 3100 5 Window
Moderated by  MNSmith
