1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Just got through rebuilding the steering box on the 38 Chev 1/2 ton. Looked in the manual and pretty much all it says is fill with steering lube. Anybody have any idea what weight oil/gear grease should be used??
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | You can't go wrong using Corn Head Grease. I use it in my 46. You can get it at any Tractor Supply location or Google the name and see what is close to you. Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Harold has provided good information. I think that the grade of original steering grease/oil is 00 Her are some other sources. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | I got some DELO NGLI 00 from drdoug here on Stovebolt. Shoot him a PM.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Checked tractor supply they have the 00 listed as cotton picker spindle grease. I have a semi local store and I need to be up that way some time soon any way to hit my welding supply outlet so I'll see if TS has it. Thanks for the help guys Dave
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | The old stand by if you can't get out, is 50/50 mix of chassis grease and gear oil. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | The old stand by if you can't get out, is 50/50 mix of chassis grease and gear oil. X 2. Thick enough not to leak but thin enough to flow........... Like pancake batter
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Harold is right on the money. Go to John Deere shop and get corn head grease. As a farmer I can add that the hotter it gets the better it works, Of course one does not need to worry about heat and a steering box unless it is close to a header. When poly lube type grease came out in the mid to late 70's the best way to check; place a marble size squirt on a steel surface and hit hard with a hammer. If it splatters its not poly. I still use poly in all my steering boxes but, Harold has changed my mind. Ed
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Harold46 is right on the money. Go to John Deere shop and get corn head grease. As a farmer I can add that the hotter it gets the better it works, Of course one does not need to worry about heat and a steering box unless it is close to a header. When poly lube type grease came out in the mid to late 70's the best way to check; place a marble size squirt on a steel surface and hit hard with a hammer. If it splatters its not poly. I still use poly in all my steering boxes but, Harold has changed my mind. Ed
| | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Thanks, Kevin.
If anyone is interested in getting some Chevron Delo EP 00 (synthetic gearbox semi-fluid grease), I still have some extra beyond my needs that I can package in either standard grease cartridges or quart-size jug containers. Just search for my posting in the Swap Meet or send me a PM.
I know lots of people use the J-D Corn Head grease, but at NLGI 0, it's just a bit thick by my way of thinking. Mobil, Shell, Chevron all make suitable EP 00 greases, the downside is just that the minimum buy is in a 5 gallon (35#) pail. I selected the Delo EP 00 because of its availability to me, its superior specs, and because its base oil viscosity matches the original spec, at SAE 90 wt, equivalent. So, I have about a 100 year supply. LOL. Just my 2 cents.
Cheers!
Doug
