Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Gdads51, Peggy M, mts), 629 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
#1353073 04/03/2020 12:33 PM
46 Chevy 1/2 Ton 1929 Model A Phaeton
I'm new to Stovebolt. I'm trying to get torque values for connecting rods and main bearings for my 46 Chevy. I've been searching the forums looking for this info and found one that says 35 - 45 for connecting rods and 100 - 110 for main bearings. My questions is are these correct torques? Would this be the same for 216, 235 and 261 engines?
fred c #1353086 04/03/2020 1:31 PM
Check here for a service manual, http://www.oldirononline.com
or, check here, http://chevy.oldcarmanualproject.com/index.htm
One or the other should have a shop manual that shows torque settings.
fred c #1353266 04/04/2020 12:01 PM
I've tried following both of the links without much luck. Here is my situation. I purchased my 46 Chevy truck about 2 months ago. I've since found out it has a pretty bay rear main oil seal leak. I know it has a 6 cylinder GM motor but I'm not sure if it's a 216, 235 or 261? I need to drop the pan, loosen the cap and main bearing to replace the oil seal. I can buy oil pan gaskets for all 3 of the motors so I hope I have that problem covered. Why I can't find out is the torque values for the bearings. I thought sure someone here on Stovebolt would know this information.
fred c #1353267 04/04/2020 12:32 PM
Why don’t you post up the #s on your engine so we can tell you exactly which engine you have. Someone here (probably many) who can then give you the needed torque values. Help us help you.🛠
fred c #1353274 04/04/2020 12:57 PM
the casting number is GM 3835124 The serial number on the block is C136011 I have not removed the starter to find the date code.
fred c #1353277 04/04/2020 1:33 PM
V
VEW Offline
V Offline
Mike B. is really good at converting the numbers, I'm not. I have assembly spec's for a 235, but that probably doesn't help you.
Someone will help out, I'm sure.
Good luck!
~ Victor
1957 3100 - moved on
fred c #1353279 04/04/2020 1:40 PM
do you know the torque specs for the cap bearings and main bearings? That would be very helpful if it turns out I have a 235
fred c #1353282 04/04/2020 1:46 PM
Here is the 1948 specifications for 216 - 235, http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0648.htm
fred c #1353284 04/04/2020 2:04 PM
V
VEW Offline
V Offline
Can't seem to locate a page that has all the specs on it, but here's the bearing cap section. 100-110 ft. lb.
~ Victor
fred c #1353287 04/04/2020 2:39 PM
Thank you all very much. This really helps.
fred c #1353399 04/05/2020 1:38 AM
I believe you have a 1947 Canadian 216 from a passenger car.
Was your car built in Canada by any chance?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
fred c #1353450 04/05/2020 12:13 PM
I'm not sure, but I was told the truck was purchased in Canada. I also found a registration card in the glove box that shows the truck was registered in British Columbia in 2009
fred c #1353483 04/05/2020 3:53 PM
Does the GVW data plate say "Made In Canada"?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
fred c #1353507 04/05/2020 5:07 PM
Yes it does. I didn't notice that before. Like I said, I've only owned the truck a little less that 2 months and half that time I was in the Florida Keys.
fred c #1353527 04/05/2020 6:26 PM
Joe H gave me the specs for a 1948 216. Do you think they would be the same for a 1947 car engine?
fred c #1353544 04/05/2020 8:02 PM
On my 1956 block the rear main bolts are only 1/2" thread the rest of the mains have 9/16 thread.
What's weird is that the bolt heads are the same size on all of them.
According to the generic chevy torque table; I'd think that the rear main should only be torqued ~75ft-lb instead of 105 as with the rest. But I haven't found any chevy instructions mentioning this.
Anyone else noticed this?
'59 Chevy Suburban, NAPCO
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.068s Queries: 15 (0.051s) Memory: 0.6643 MB (Peak: 0.7857 MB) Data Comp: Zlib Server Time: 2025-09-21 23:07:10 UTC
Valid HTML 5 and Valid CSS
