2 members (klhansen, Peggy M), 167 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#135292 09/05/2006 8:12 PM
Junior Member
Junior Member
I am installing a 350 small block and turbo 350 in a 1950 Chevy Truck. The truck has been lowered. It looks like there could be a clearance issues with the driveshaft and center cross member (between cab and bed?) Has anyone ever run into this and what would be the best solution?
Frank
1949 Chevy 3800
1929 Chevy International
#135293 09/06/2006 5:24 AM
you can put a two pc drive shaft, you can also c notch it
1949 SUBURBAN
#135294 09/06/2006 1:10 PM
Anonymous
Unregistered
Anonymous
Unregistered
Should not be any problem. If there is then you have the truck too low to begin with.
#135295 09/07/2006 4:05 AM
Strangley enough, I just installed my drive shaft today. I put in a small block/350 turbo and a 76 Olds 442 rear end.The driveshaft just dropped right in and no clearance problems.
Lothar
