| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 34 Junior Member | | Junior Member Joined: Oct 2005 Posts: 34 | I am installing a 350 small block and turbo 350 in a 1950 Chevy Truck. The truck has been lowered. It looks like there could be a clearance issues with the driveshaft and center cross member (between cab and bed?) Has anyone ever run into this and what would be the best solution?
Frank 1949 Chevy 3800 1929 Chevy International
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | you can put a two pc drive shaft, you can also c notch it | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Should not be any problem. If there is then you have the truck too low to begin with. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Strangley enough, I just installed my drive shaft today. I put in a small block/350 turbo and a 76 Olds 442 rear end.The driveshaft just dropped right in and no clearance problems. Lothar | | |
