2 members (KEVINSKI, stlcardinalsguy), 100 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
Can I ask someone(s) to measure length of fleetside and stepside rear bumper? 60-66. I have what I believe now is a fleetside bumper (75 in length). Would like to confirm so I know for sure what I have. Is the suburban bumper also different so that maybe I have a suburban bumper?
By the way I am a bit embarrassed to have stored this bumper under my bed for 2 yrs thinking it was perfect.
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
Possible Answer?
Thanks that clears up the ste0 side. I will poke around that site for the others
~ HB
1962 Chevrolet C10
1962 Suburban
1 final question. Is the suburban bumper same as fleetside? Vendors catalogs do not list a suburban bumper but that may not be the conclusive.
~ HB
1962 Chevrolet C10
1962 Suburban
Measuring by myself with a tape measure I come up with 76" for Fleetside.
[img]https://i.postimg.cc/nMhs9CXL/IMG-5038.jpg[/img]
Evan
Thanks.
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
I believe the suburban uses the same bumper front and rear. No license plate dip in rear. I believe coilover has a 67-72 Fleetside bumper. Don't think it's a flipped 60-66.
Frame is narrower in the front then the rear, so although they look the same on a panel the bolt holes don't line up by a good margin .
good planning is no substitute for dumb luck
Sir Searchalot
Sir Searchalot
TF panels and suburbans use same bumper front and rear, Thought the 60-66 did also? Sure would save GM money.
John if you would, next time you are in the garage measure length of rear bumper. I should have recalled you had one of those
~ HB
1962 Chevrolet C10
1962 Suburban
H B both bumpers measure 78 1/2 in. long while the inner bolt to bolt on front measure 26 1/2 the rear measures 44 1/2 bolt to bolt .
Mine being a 1 ton has been extended a couple of feet but your c 20 should have the same frame as a standard panel, whats your rear bumper holes measure at.
Thanks for the measures John. Mine bumper (presumed to be a fleetside bumper) is 75 in long. 35 1/2 inner bolt to bolt.
~ HB
1962 Chevrolet C10
1962 Suburban
Socket Breaker
Socket Breaker
That is a fleetside bumper on your truck, it's flat on the back side, from side to side.
The step side bumper curves toward the cab on each side.
you can see the how the step side bumper curves and points in these pics here:
pics of my '65 stespide
-Woog
That does it. Thanks for all the learning.
~ HB
1962 Chevrolet C10
1962 Suburban
Socket Breaker
Socket Breaker
That's why we are all here. grin
-Woog
