1 members (klhansen ),
160
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,132
Posts1,056,729
Members48,454
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Can I ask someone(s) to measure length of fleetside and stepside rear bumper? 60-66. I have what I believe now is a fleetside bumper (75 in length). Would like to confirm so I know for sure what I have. Is the suburban bumper also different so that maybe I have a suburban bumper? By the way I am a bit embarrassed to have stored this bumper under my bed for 2 yrs thinking it was perfect.
Sir Searchalot
Sir Searchalot
Thanks that clears up the ste0 side. I will poke around that site for the others
1 final question. Is the suburban bumper same as fleetside? Vendors catalogs do not list a suburban bumper but that may not be the conclusive.
Sir Searchalot
Sir Searchalot
I believe the suburban uses the same bumper front and rear. No license plate dip in rear. I believe coilover has a 67-72 Fleetside bumper. Don't think it's a flipped 60-66.
Frame is narrower in the front then the rear, so although they look the same on a panel the bolt holes don't line up by a good margin . John
good planning is no substitute for dumb luck
Sir Searchalot
Sir Searchalot
TF panels and suburbans use same bumper front and rear, Thought the 60-66 did also? Sure would save GM money.
John if you would, next time you are in the garage measure length of rear bumper. I should have recalled you had one of those
H B both bumpers measure 78 1/2 in. long while the inner bolt to bolt on front measure 26 1/2 the rear measures 44 1/2 bolt to bolt . Mine being a 1 ton has been extended a couple of feet but your c 20 should have the same frame as a standard panel, whats your rear bumper holes measure at. John
Thanks for the measures John. Mine bumper (presumed to be a fleetside bumper) is 75 in long. 35 1/2 inner bolt to bolt.
Socket Breaker
Socket Breaker
That is a fleetside bumper on your truck, it's flat on the back side, from side to side.
The step side bumper curves toward the cab on each side.
you can see the how the step side bumper curves and points in these pics here:
pics of my '65 stespide -Woog
That does it. Thanks for all the learning.
Socket Breaker
Socket Breaker
That's why we are all here.
-Woog
