3 members (Naturalthud, Southerntruck, Peggy M), 285 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#135241 08/31/2006 5:11 AM
Ok guys, I've got a question for you. With a stock 235 with fentons a two barrel or dual singles, a t-5 (or 200r4), and 3:55 gears, how much speed can I realisticly expect? I want a driver which will be used frequently on the interstate.
Robert C.
I'm a Genius in the making.
1950 3600
(RPM x Tire OD)/(Trans Gear Ratio x Rear Gear Ratio x 336.1)=MPH
Here is another excellent source if you want to calculate online:
http://www.classictruckshop.com/garage/shopmathgearcombo1.asp
I found it very helpful in considering any number of tranny / rear end combinations.
______________
Guy
______________
'67 C-10 283/350
With a 27% overdrive, and 28 inch tall tires 97 mph at 3000 rpms. Plenty fast... just make sure the rest of your truck is up to it... brakes, steering, suspension, and SHEET METAL. Those speeds could rip loose sheet metal right off. grin grin grin
I only manage about 70 tops on my 1952 3/4 ton, with M420 4-speed, 4.56 gears, 1:1 final drive, and 32 inch tall tires. And that's buzzing the tach at about 3800 rpm on my 235.
With 3.55 gears, suffice it to say, you should be able to keep up with traffic...on a long straightaway or slight decline.
(235's are very weak motors).
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
Another calculator:
http://www.csgnetwork.com/multirpmcalc.html
I found this easier to use plus there are a bunch more calculators at the bottom of the page.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
How much speed can you expect?
More than you truck can safely handle, even with brakes, shocks, steering and suspension repairs.
So, enjoy yourself and be safe!
