2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Ok guys, I've got a question for you. With a stock 235 with fentons a two barrel or dual singles, a t-5 (or 200r4), and 3:55 gears, how much speed can I realisticly expect? I want a driver which will be used frequently on the interstate.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | (RPM x Tire OD)/(Trans Gear Ratio x Rear Gear Ratio x 336.1)=MPH | | | | | Joined: May 2006 Posts: 63 Member | | Member Joined: May 2006 Posts: 63 | Here is another excellent source if you want to calculate online: http://www.classictruckshop.com/garage/shopmathgearcombo1.asp I found it very helpful in considering any number of tranny / rear end combinations. ______________ Guy ______________ '67 C-10 283/350 | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I only manage about 70 tops on my 1952 3/4 ton, with M420 4-speed, 4.56 gears, 1:1 final drive, and 32 inch tall tires. And that's buzzing the tach at about 3800 rpm on my 235.
With 3.55 gears, suffice it to say, you should be able to keep up with traffic...on a long straightaway or slight decline. (235's are very weak motors).
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Another calculator: http://www.csgnetwork.com/multirpmcalc.html I found this easier to use plus there are a bunch more calculators at the bottom of the page. | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | How much speed can you expect?
More than you truck can safely handle, even with brakes, shocks, steering and suspension repairs.
So, enjoy yourself and be safe!
