6 members (Otto Skorzeny, MikeE, Hotrod Lincoln, ShopRag, TooMany2count, J Lucas), 32 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#1351702 03/26/2020 2:06 AM
Can anyone tell me what the difference is between a steering box/mast from a '54 vs the earlier ADs?
Can a '52 box/mast be used in a '54?
52Carl #1351704 03/26/2020 2:18 AM
"Can anyone tell me what the difference is between a steering box/mast from a '54 vs the earlier ADs?"
The 1954 steering mast has holes in it for the RPO/Accessory turn-signal wire-harness.
And, there is a different "cover/cone" around the steering column, under the steering wheel.
"Can a '52 box/mast be used in a '54?"
I do not know, but, I would bet "yes"; but (again), wait to hear from others.
52Carl #1351716 03/26/2020 3:53 AM
1954 was the first year for built in turn signals, so the column has a cutout for the wires to run down the inside of the column.
My Blog
52Carl #1351730 03/26/2020 11:58 AM
Dave,
Except for those differences in the 1954 steering column, could someone use an earlier 1/2-ton column in a 1954/55st truck?
Would it bolt-right-in/on - you would use the earlier steering wheel/collar?
52Carl #1351750 03/26/2020 3:11 PM
I can not think of a reason the earlier box would not fit.
Same splines for pitman and steering wheel, and same mounting.
The parts book shows the 1947-53 steering shaft to be 5/16" longer on the 1954.
My Blog
