4 members (Joe H, Phak1, GMCJammer51, moparguy), 53 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
Need some help guys. I removed the 235 and transmission from my 55 task force 3100 and installed a rebuilt
1969 chevelle 307v8 with attached Saginaw 3 speed transmission. Can anybody tell me where to find the clutch linkage needed to get this to work and I also need the shift kit assembly for a floor mount for the Saginaw 3 speed.
I also would like to keep the floor starter pedal for starting. Somewhere I read in the past year someone converted to a newer engine and kept it. Anyone know who it was so I could get some advice.
Thanks much
Jim S
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
The original clutch throughout arm from the 6 cylinder bellhousing can be used with the V-8 bellhousing. All of the other stock clutch linkage remains the same as well. Stock replacement linkage components are available from a number of aftermarket suppliers, Truck Shop, Brothers, etc. Floor shift conversion kits are available on craigs list and ebay as well.
I made a plate for the floor starter to leave it in the same location. It doesn't do anything but looks original.
Fred
If you get a v8 bell housing all of the linkage you removed will work.
Tommy
59 apache 1/2t
261 short stepside
Thanks guys. It's been awhile since I removed it and looking at the clutch fork and location, I didn't think it would work.
Fred, I was going to do that with the starter as a last resort.
Jim
1955 Chevy series 2
