2 members (Hotrod Lincoln, 1 invisible),
137
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 45 'Bolter | | 'Bolter Joined: Jul 2017 Posts: 45 | Need some help guys. I removed the 235 and transmission from my 55 task force 3100 and installed a rebuilt 1969 chevelle 307v8 with attached Saginaw 3 speed transmission. Can anybody tell me where to find the clutch linkage needed to get this to work and I also need the shift kit assembly for a floor mount for the Saginaw 3 speed.
I also would like to keep the floor starter pedal for starting. Somewhere I read in the past year someone converted to a newer engine and kept it. Anyone know who it was so I could get some advice. Thanks much Jim S
Jim
1955 Chevy series 2 6 cylinder, 3 on the tree Short bed, step side
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The original clutch throughout arm from the 6 cylinder bellhousing can be used with the V-8 bellhousing. All of the other stock clutch linkage remains the same as well. Stock replacement linkage components are available from a number of aftermarket suppliers, Truck Shop, Brothers, etc. Floor shift conversion kits are available on craigs list and ebay as well. I made a plate for the floor starter to leave it in the same location. It doesn't do anything but looks original. Fred
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you get a v8 bell housing all of the linkage you removed will work.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2017 Posts: 45 'Bolter | | 'Bolter Joined: Jul 2017 Posts: 45 | Thanks guys. It's been awhile since I removed it and looking at the clutch fork and location, I didn't think it would work. Fred, I was going to do that with the starter as a last resort.
Jim
