5 members (Wally / Montana, Chris's 46 / 515, mick53, Stovebolt48, 1955 1 Series), 133 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#135107 08/20/2006 5:35 PM
Junior Member
Junior Member
I have a pair of heads from a 85 305 camaro. Will they fit on a 1958 283 block? Thanks for your help. Mack
#135108 08/20/2006 7:18 PM
Mack, If you can tell me the casting # I can tell you the spec's for the heads are.
Will they fit a 283 ? YES . The casting # for the block would help.
George Hood
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
#135109 08/21/2006 11:33 AM
Hey Mack,
Where are you? I have a set of stock 1966-1967 283 heads with a valve job, hardened seats and new seals just sitting here.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#135110 08/21/2006 4:39 PM
Apprentice
Apprentice
Pablos,
How much for the 283 heads? I am rebuilding a 67 283 for my truck and could use them.
MACZ
#135111 08/21/2006 6:05 PM
Pablos, are those heads from a 2bbl or a 4 bbl ? I have a set of heads with the big valves (2.02 1.60) with 500 miles on a rebuild. I prefer the smaller valves. (1.9 1.5)
55 Cabover
#135112 08/21/2006 9:54 PM
The engine they were on originally on was a 2 barrel set-up. I'll drag them out and check the casting #s and maybe I can find out something.
#135113 08/21/2006 9:55 PM
MacZ, don't how to get them to you. Freight might be pretty high.
#135114 09/07/2006 1:31 AM
put them on a grayhound bus...
Another quality post.
Real Trucks Rattle
#135115 09/09/2006 10:52 AM
I haven't seen a greyhound bus in years.
#135116 09/10/2006 10:08 AM
I've rolled 'em up in cardboard before and mailed 'em USPS.
#135117 09/10/2006 2:35 PM
will a pair of 307/327 heads work for you ? I have a set in the swap meet section on page 6 or 7.
casting# 3911032....68......307/327......70cc chamber
1951 3100 Chevrolet
#135118 09/12/2006 5:23 AM
Yes. To get back to your question, 305 heads will work on a 283, and the combustion chamber size is very close too.
I had a set of old Corvette dual-quad 283 heads that I recently gave away. I wish I new earlier, I'd have let you have them.
The 305 heads have bosses drilled and tapped for accessories that the 283 heads lack. Other than that, very similar.
BTW, I wouldn't suggest 70cc heads on a 283 unless you need really low compression for forced induction. 305 heads were 58 cc's and 283 heads were slight less than that, if I remember.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
