| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 4 Junior Member | | Junior Member Joined: Jun 2003 Posts: 4 | I have a pair of heads from a 85 305 camaro. Will they fit on a 1958 283 block? Thanks for your help. Mack | | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Mack, If you can tell me the casting # I can tell you the spec's for the heads are. Will they fit a 283 ? YES . The casting # for the block would help. George Hood
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Hey Mack, Where are you? I have a set of stock 1966-1967 283 heads with a valve job, hardened seats and new seals just sitting here.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Apr 2006 Posts: 21 Apprentice | | Apprentice Joined: Apr 2006 Posts: 21 | Pablos,
How much for the 283 heads? I am rebuilding a 67 283 for my truck and could use them.
MACZ
| | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | Pablos, are those heads from a 2bbl or a 4 bbl ? I have a set of heads with the big valves (2.02 1.60) with 500 miles on a rebuild. I prefer the smaller valves. (1.9 1.5)
55 Cabover
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | The engine they were on originally on was a 2 barrel set-up. I'll drag them out and check the casting #s and maybe I can find out something.
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | MacZ, don't how to get them to you. Freight might be pretty high.
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | put them on a grayhound bus...
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I haven't seen a greyhound bus in years.
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | I've rolled 'em up in cardboard before and mailed 'em USPS. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | will a pair of 307/327 heads work for you ? I have a set in the swap meet section on page 6 or 7.
casting# 3911032....68......307/327......70cc chamber 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yes. To get back to your question, 305 heads will work on a 283, and the combustion chamber size is very close too.
I had a set of old Corvette dual-quad 283 heads that I recently gave away. I wish I new earlier, I'd have let you have them.
The 305 heads have bosses drilled and tapped for accessories that the 283 heads lack. Other than that, very similar.
BTW, I wouldn't suggest 70cc heads on a 283 unless you need really low compression for forced induction. 305 heads were 58 cc's and 283 heads were slight less than that, if I remember.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
