7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
I have a 1965 short step every day unmolested driver, the cab is all metal.
what are the best options for reducing cab noise?
thanks
stovebolt409,
Laying down sound deadening/dampening mats, can work well. A couple of restoration shops in my area, recommended Deimos Deals. They carry, what appears to be the same kind of product that a Dynomat, or other brand name carries, for a fraction of the cost. I purchased and installed it in my 53 3100. It worked really well. Much quieter than before. Know doubt there are a number of other manufactures of similar products. But, they get my vote for a relative inexpensive way to achieve your goal. Here is a link to them.
https://www.ebay.com/str/deimosdeals
Hope this helps you with your restoration.
Rugo
Steve Rugg
53 3100
I replaced the rubber isolators between the cab and cab mounts on my '53. That made a very noticeable difference. Use something like Dynomat everywhere you can hide it - backside of the dash, inside the doors, firewall, floorboard, on the cab behind the gas tank, even stick a piece on the gas tank. I don't recall how the '65 seat mounts in the cab, but if you can isolate the seat from the floor with rubber washers+carpet, etc that will also make a difference. I tried several different carpet pads, sound deadeners jute pads, etc. and found the absolute best thing is a closed cell carpet pad I got from a home carpet supplier. It's a waterproof sound and temperature barrier that works great! I ran it from under my dash all the way back to the gas tank. I then covered that with interior carpet I got from the same place. It's cheaper and heavier than auto carpet. The problem with your truck is you've got lots of flat hard surfaces - dash, doors, windshield, cab roof and even (I'm guessing) a vinyl seat. Not only do these surfaces transmit road, wind, and engine noise into the cab, they also bounce that noise around and aim it at your head. You could modify your truck with a cloth headliner, full door panels, and a cloth seat, or wear earplugs. I'm doing both smile
In addition, you may benefit from using a spray on undercoating or bedliner on the exterior of the floorboard. Just a thought for something that would be relatively simple.
I haven't done it yet but I have purchased Hushmat. Similar to Dynomat. All the reviews I have read indicate the users had good results. I am in the middle of replacing floor pans. Once that is done I am going to put down the Hushmat and see what happens. It definitely roars right now. Anything will be an improvement.
Dave from Northern Kentucky
My 54 3100
Unconventional Thinker
I used the sound deadening sheets (2 Layers Thick) from LMC beginning just under the jute firewall pad, to under the gas tank. It helped. But there needs to be more, so I am going to get some insulation soon to combat noise and heat. The seat is coming out anyway to cut a big hole in the floor to accommodate the high hump, so why not add more stuff to the floor while I'm at it, right...lol...
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
I used Dynamat over every exterior metal part (inside the cab). Floors, fire wall, behind fuel tank, roof, inside doors, etc. that helped a ton. I decided to use the water heater insulation (bubble wrap with foil on both sides) under the jute padding and I taped it to the floor with the metal tape for duct work. Once I put the carpet/jute down, I can talk to my kids without yelling. Obviously, my truck get hot inside due to Texas heat, but I think it’s just the hot air (maybe my hot air)! The other thing I decided to do was tint my windows with ceramic 70%. This has helped a great deal with heat!
Do not get the sound deading from LMC, the one that says is asphalt, mine came dried out and cracked so I just gave it away.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I used thermotec:
https://www.summitracing.com/parts/the-14620/overview/
Easy to cut and stick, coated top of cab, under dash cowl, inside of doors, rear of cab and all the floors even under the seat. Results were a world of difference, money well spent.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I'm going to spray Lizard Skin Ceramic and Sound control in my 48 shortly.
I insulated and soundproofed much like most are recommending. It definitely dampens the sound. But honestly, I think the biggest reduction in cab noise was the result of sticking the sound barrier to the underside of the hood.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Man o man...I never thought about adding sound deadening to quiet a noisy cab...I just thought when I was driving an old smelly truck that it should creak and groan and bang when you drove it....I could even hear the tires rolling on the pavement...
I bet that would have made driving my old heap a tad bit more tolerable....never even thought about it ...
Thanks for the insight...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
I added dynamat to everything metal that would create sound. After that, I added the bubble wrap with tin foil from Lowe’s and put my carpet over that. That quieted my cab a lot and I finally put ceramic tint on all windows to deflect the heat! What an amazing difference.
Chris
I see many people adding insulation to the doors...inside or outside skin?
I did both (strips) on the inside of the door. Now it does not have the tin echo!
Chris
Hello hello heeellllooo.
I'm definitely interested in some of these products. Since there is almost nothing left of the original stuff on my 67 burb.
Another quality post.
Real Trucks Rattle
I use peal and seal self stick roofing from Lowes. a lot cheaper than sound deadener.
Water proof and flexible. This is the stuff used under roofing.
Most of the stuff is black but I had some that was foil backed that I put in my Beetle and it made a huge difference.
I just cleaned floor and stuck it down. Then used heat gun to work it into grooves and dips. Put underlayment over that and carpet on top. What a huge difference it made.
https://www.lowes.com/pd/Grace-Cons...0-sq-ft-Rubber-Roof-Underlayment/3064819
1955 GMC 150, 1980 Chevy C10, 2011 Sierra 3500 HD SLT Duramax Dually Crewcab, 1960 Chevy BelAir 2dr sedan, 1978 Pontiac Trans-Am
https://www.lowes.com/pd/Peel-Seal-...n-x-25-ft-Aluminum-Roll-Flashing/1018733
I used Fatmat in a small section. Then bought this from Lowes. It is the exact same stuff without the high price. No Smells ect. Worked great!
Was a Night & Day difference.
Inside doors, floor, gas tank.ect...
//// I can hear my 1950 AM radio Truckernix fixed for me !
There are several Original ones for sale right now..here's one
https://www.ebay.com/itm/143555636493
1950 Chevy 3100
I just turn the radio up......... nanner
Craig
I used the peel and seal in my '49. I now want a radio since I will probably be able to hear one now. smile
2 Offline
I might know a guy that can help u with that radio
-s
I put a RetroSound Laguna radio in my 49 and it fit really well. I haven't got it wired up yet as I have to much wind noise coming in. Waiting on the weather to warm up before I install the SoftSeal.
https://www.jegs.com/i/RetroSound/7...DZG-oDL-AXc1FInl2Olbo632c9caAiv6EALw_wcB
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
I'm surprised nobody has mentioned mass loaded vinyl.
According to some, it is way more effective than dampener sheets.
Unfortunately these guys are out of business, but their website still has a great discussion & comparison of the different sound deadening strategies
https://www.sounddeadenershowdown.com/products
Mass loaded vinyl is what I want someday... it would be interesting to hear if anyone here has tried it?
'59 Chevy Suburban, NAPCO
Not MLV, but several years ago several folks in the Dodge diesel world were using sheet lead to line the floor and firewall and covering it with peel and stick from the big box stores. Sheet lead is rated at lbs per sq. foot and with a Dodge Cummins truck that bit of extra weight is pretty insufficient. As I recall the results were very good at quieting the Cummins. I suspect it'd work well in our trucks in the floor and on the firewall with the same peel and stick on top.
RonR
RonR
1970 340 Duster
1964 CJ5
If you put sheet lead in your truck in CA, it would be classified as a hazardous site. Of course everything else in CA is hazardous to your health. dang
Anything that adds mass to the component will work. Even a blob of tar or undercoating that changes the natural frequency of the component would help, with varying results.
It doesn't seem to bother Led Zeppelin at all!!
Moderated by  ndkid275, Phak1
