1 members (JW51), 98 guests, and 3 robots.
Topics128,055
Posts1,055,782
#1350576 03/18/2020 9:14 PM
I know it just was st paddys day but... my old truck has a miss and thought it may be water in the gas so i drained some into a glass jar to look at and it was green !! Smells old no water sep,I had put stabil additive in it recently.It has rec 90 gas which is suppost to be low alcohol . Any thoughts?
As for the miss plugs look good , not backfiring just seems low on power and has a stutter from 900 to 2500 rpm. idles ok.
59chevy36 #1350583 03/18/2020 9:25 PM
Are you sure it's not diesel? That has a slight green tinge to it.
59chevy36 #1350590 03/18/2020 9:37 PM
don't think its diesel. Had some rec90 in a can that's new it looks clear, put a few drops of stabil in still clear. ? could old gas be growing a mold?
59chevy36 #1350592 03/18/2020 9:46 PM
Green gas?
St. Patrick's Day was yesterday. chug
59chevy36 #1350595 03/18/2020 10:13 PM
Have you had any work done to the fuel tank? A liner kit
59chevy36 #1350600 03/18/2020 11:08 PM
Sounds like old gas to me. Always turns green. If fuel level is low enough, you might be able to add enough new gas to burn through it. Otherwise, siphon/drain it.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
59chevy36 #1350618 03/19/2020 12:07 AM
Not being irish didn't know it had passed , could be old gas. gona drain the tank this week and see what that does. looked/smelled some reg gas e85 and the diesel for the tractor both are clear and smell like they should. when I say green I am talkin lime jello green not just a tint.
59chevy36 #1350623 03/19/2020 12:28 AM
Ive had old gas turn a honey color
Might be a good idea to clean lines, maintenance on carb
59chevy36 #1350639 03/19/2020 2:44 AM
How old is the Green Gas?
Do you have copper fuel lines?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
59chevy36 #1350641 03/19/2020 3:02 AM
Insomniac
Insomniac
If you lived here and the gas was purple, I would say you used the pump that's for boats and farms. Purple gas is not for highway use - no road tax paid.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
59chevy36 #1350647 03/19/2020 3:57 AM
Are you looking in the fuel tank or the radiator? Kidding!
59chevy36 #1350902 03/21/2020 1:57 AM
Gas is prob 6 mo old. all lines are aluminum. looks like rad fluid but still burns. put the old gas in the lawn mower and it did fine. gona get the rest out this w.e. and use new gas. hope the stutter goes away.
59chevy36 #1350905 03/21/2020 2:09 AM
Has the engine ben run on this bad gas?
