| | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | As usual one should always plan to spend twice as much as they expect too when working on projects. I put a T-5 in my 52 Chevy pickup and then realized that:
1. The clutch that came out originally was a 9 1/4" so the RCF-4201 (9 11/16) is too big.
2. The pressure plate does not need replaced if the original is not warped.
3. If you put in the wrong clutch and a new pressure plate and crank the motor you may not be able to get your money back.
So... trying to do more homework here. The RCF-4190 is a 9 1/8" 14 spline 1" clutch disc and will fit the original pressure plate with no modifications. Napa lists it as originally coupled to a raised diaphragm pressure plate and the stock pressure plate is a flat diaphragm. Is this right?
New drive shaft will be here Monday! Hoping to have this thing ready to drive by then! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | jthuma94,call best bilt clutches 417-831-4470 and talk to berry(springfield,mo).I did a lot of research before i bought a clutch disc.They have a valeo brand #38-4190 that will do the trick with the 9 1/4" pressure plate. He said it lists for a 1983-1984 2.0 s-10 pickup.I purchased a 4190 here locally and the center hub would not fit inside the pressure plate.I called best bilt and give them all of the dimensions of the pressure plate and throw-out bearing,he set me up.With shipping the disc cost me $50.37.I tried the same disc you are talking about,it would not clear the center of the pressure plate,so i took it back.Call berry,he will help !! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Aug 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 99 | I checked with the FLAPS and they have several 9 1/8 14 spline 1" discs in stock so I am going to go down with the pressure plate and have a look at what fits best. Thanks for the tip. The driveshaft will be here Friday so maybe I can wrap this up over the weekend. | | |
