| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | Hey Guys, What year range spindles will bolt directly to 1965 1/2 Ton factory upper and lower control arms? :confused: | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You should be able to use the '73-'87 spindles, if you change the ball joints to the later style. Moog part #s K6136-upper, K6117T-lower.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | I've got another post about this same question. Can I use the complete front cross member , springs , a-arms , spingles, steering box and all? Mine is a 65 c/10 non-power steering and brakes. The donor is a 82 w/ p/s and p/disc brakes. I was told that if you remove all the bolts and rivets ya could just interchange the two. True? Thanks, George Hood
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
| | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | George- YES it is true. I just started that process with my 65. The 84 C10 donor I had was exactly the same. I opted to swap in the 84 spindles (with 84 ball joints) since my 65 had nicer a-arms. Tie-rods are the same but the piece that bolts to the frame on the right side is different. Takes some modifying of the frame to get the steering box mounted. | | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Jim , Thanks. Does someone make an adapter That will work ? George Hood
| | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Wil an 75 steering box and a - arms work ? The 82 that I bought to use the front end out of just runs too good to strip. Thanks , George Hood
