1 members (edgardo), 79 guests, and 3 robots.
Topics128,057
Posts1,055,808
#135049 08/15/2006 3:36 AM
Junior Member
Junior Member
Hey Guys,
What year range spindles will bolt directly to 1965 1/2 Ton factory upper and lower control arms? :confused:
#135050 08/15/2006 3:43 AM
You should be able to use the '73-'87 spindles, if you change the ball joints to the later style.
Moog part #s K6136-upper, K6117T-lower.
Bill Burmeister
#135051 08/19/2006 6:32 PM
I've got another post about this same question.
Can I use the complete front cross member , springs , a-arms , spingles, steering box and all?
Mine is a 65 c/10 non-power steering and brakes. The donor is a 82 w/ p/s and p/disc brakes. I was told that if you remove all the bolts and rivets ya could just interchange the two.
True?
Thanks, George Hood
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
#135052 09/01/2006 2:35 AM
George- YES it is true. I just started that process with my 65. The 84 C10 donor I had was exactly the same. I opted to swap in the 84 spindles (with 84 ball joints) since my 65 had nicer a-arms. Tie-rods are the same but the piece that bolts to the frame on the right side is different. Takes some modifying of the frame to get the steering box mounted.
1965 Chevy C-10 Longbed Stepside
#135053 09/02/2006 3:09 AM
Jim , Thanks.
Does someone make an adapter That will work ?
George Hood
#135054 09/16/2006 6:29 PM
Wil an 75 steering box and a - arms work ?
The 82 that I bought to use the front end out of just runs too good to strip.
Thanks , George Hood
