| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | will a 4.3 v6 fly wheel from a 93 fit on an older 350 and work for a maunal tranny ??????
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Dont have an answer for ya but post this at www.hotrodders.com. You will get a quick answer. | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | if the 350 is older than 1986 i would say it won't work because before 86 the crank flanges had a balance bobweight on them and the old style bolt pattern. if the 350 is after 86, it will probably bolt to the new style round flange of the 93 flywheel but the balance of the flywheel might be wrong for the 350.hope this helps.
our garage is a non-profit organization
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | walk over to the motor and hold the flywheel up there. that should probably tell you | | |
