0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#134945 08/04/2006 3:31 AM
will a 4.3 v6 fly wheel from a 93 fit on an older 350 and work for a maunal tranny ??????
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#134946 08/05/2006 4:54 AM
help me please
AND A MARINE
#134947 08/05/2006 5:32 AM
Dont have an answer for ya but post this at www.hotrodders.com. You will get a quick answer.
#134948 08/06/2006 12:12 AM
if the 350 is older than 1986 i would say it won't work because before 86 the crank flanges had a balance bobweight on them and the old style bolt pattern. if the 350 is after 86, it will probably bolt to the new style round flange of the 93 flywheel but the balance of the flywheel might be wrong for the 350.hope this helps.
our garage is a non-profit organization
#134949 08/06/2006 1:14 AM
walk over to the motor and hold the flywheel up there. that should probably tell you
