8 members (Joe H, Joe Lowe III, frogfarmer, Shade Baby, 3B, Oswald, Cosmo, 1 invisible), 66 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1349226 03/08/2020 3:49 AM
any one have a good clear picture of the parking brake pedal set up for a 1952 3100 ? I have a pedal that works but no locking parts, no hole in the floor where I have seen pictures of a curved rod going down to some thing ? found the release rod in the back but not sure what it hook to. Thanks
woof359 Family 1952 3100 5 Window
woof359 #1349228 03/08/2020 4:15 AM
....50 1/2 ton...
Not sure if above link will work or if same as your year
woof359 #1349229 03/08/2020 4:16 AM
Here is what all the parts look like, the short upright on the Z-bar is where the rod attaches back to the center bar that pulls the cables.
https://www.flickr.com/photos/advance-design_parts_co/8129470811/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/49632576498/in/album-72157631868452754/
woof359 #1349238 03/08/2020 12:25 PM
woof359 #1349254 03/08/2020 2:20 PM
woof359--make sure the 4.603 rod is clean/no paint--sand it smooth..Had trouble years back when installed in my 49--Bill
woof359 #1349256 03/08/2020 2:39 PM
No hole in floor panel?
woof359 #1349260 03/08/2020 3:43 PM
Originally Posted by DADS50
[quote=woof359]no hole in the floor where I have seen pictures of a curved rod going down to some thing ? found the release rod in the back but not sure what it hook to. Thanks
Quote
Was that floor panel replaced/repaired (by you, or, by previous owner)?
woof359 #1349274 03/08/2020 8:03 PM
Haunting the SBP since 2001
DADS50 #1350582 03/18/2020 9:25 PM
those pictures helped alot, many thanks
previous owner took it some where, nice job but the didnt redo the e brake hole or mounting pointes
woof359 #1350603 03/18/2020 11:15 PM
They didn't do you any favors
Is the parking brake bracket assembled? That will locate the hole for you
DADS50 #1350739 03/20/2020 12:14 AM
Attached is photo of the bare-metal flange (correct term?) where the pedal and shaft assembly go thru the floor panel in my '48 Chevy 1/2 ton truck. Did it come off the assembly line looking like this, or should it be painted black? Also, what did the original fasteners look like? I do realize that very few people will ever see it with it being covered by the floor mat. Thanks. LUKE
fonz8261 #1350767 03/20/2020 3:34 AM
Looks correct to me. Probably cadmium plated originally. Rustoleum Silver Metallic spray paint makes for a wonderful replication of cadmium plating if sprayed over Rustoleum Self-etching primer. It flows horribly and somewhat splotchy, which matches Cadmium plating perfectly.
52Carl #1352654 03/31/2020 11:19 PM
Here is the "after photo"--the cleanup is complete...
