2 members (Don88, Nick in Manitou), 111 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#1348538 03/02/2020 2:28 PM
I have a 1956 6100 with a 261. The lid on my air cleaner is rusted through in the middle right were the wing nut tightens down. Does anyone sell just the lid to this style air cleaner? I found on the "bay" a complete air cleaner unit but I really only need the lid, everything else is in good shape. Thanks
Place a Want Ad in the Swap Meet. I have never seen one for sale new.
As you know, eBay for used/new?
I have that same cleaner
Dont think you'll find anything close. Try posting in the parts wanted section of the forum, someone parting out a big bolt might have one
You may end up having to try to get a whole unit or repair yours
Interesting info on that cleaner from tclederman
https://www.stovebolt.com/ubbthread...her-air-cleaner-question.html#Post614612
H Online: Content
That should be an easy fix. Weld or braze a 1/4" fender washer into the rusted area and do a little cleanup work on the weld with a die grinder or a Dremel tool. With a little sanding and paint work the fix should be virtually invisible.
Back when I had a 235 and wanted to use a paper air cleaner, I raided the kitchen.
Thanks for the replies, all good suggestions.
