2 members (Donf, Otto Skorzeny), 99 guests, and 4 robots.
Topics128,129
Posts1,056,693
Members48,452
#1347592 02/23/2020 3:19 PM
Guys,
I think my wife and I are done with the Ah-ooo-Gah Horn. We had it in our 37 and now in out 49 pickup. Looking for a nice low tone horn for our 49 pickup. We kinda like the looks of the horns in the pics. I assume they come from the 30's or 40's. Show us what do you have in your AD?
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
That looks like the one on my 48
harv #1347605 02/23/2020 5:13 PM
What year is the horn in your 48?
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Those horns are correct for '47-'52 (maybe a little later, not sure).
As usual, Carl is correct.
The switch to a single "sea shell" style horn on the intake manifold took place in 1953.
In 1954, the single "sea shell" style horn was mounted low, forward of the radiator housing (it cannot easily be seen)..
Thanks for the info guys.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Does anybody make an aftermarket horn of this style?
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Cruisin' in the Passing Lane
olezippi,
This horn may not be aftermarket, but I did a quick search on eBay and I believe this is close to what is in your pictures.
Go to eBay and type in "Original 1947-53 Chevrolet GMC Pickup Truck Trumpet Horn 6V OEM Delco GM".
...and Tim, thanks for helping to confirm that the horn on my truck is most likely original to my truck. It is the "sea shell" type and located exactly as you described.
Former owner of a 1954 3100 w/Hydra-Matic
"To know what you know and what you do not know, that is true knowledge." - Confucius
SmithLakeChevy,
A warning/heads-up to members looking for a "sea shell" type horn for a truck:
The attachment studs on the similar car "sea shell" horns are in a different location on the horn-body compared the stud-location on the "sea shell" horns used on trucks (used on trucks as regular equipment in 53-55st and used in the truck accessory/optional dual horns in several Advance-Design years).
SmithLakeChevy,
Duly noted.
Originally Posted by SmithLakeChevy
olezippi,
Thanks. I saw that one. I was unable to contact the seller.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
olezippi,
I went back to the link you gave above this morning an when I click on contact seller it will not let me sign on through Ebay or Facebook. I can sign on to both but when I try it through the ad it won't let me. I thinking it's a scam so I give up on that one.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Olezippi,
I started a new thread and placed a link in the eBay and Craigslist links forum for the horn and it appears to be working. I did not see the problem, but I did not actually try to contact the seller. (I pulled it up but did not go through with contacting the seller it since I do not actually need the horn.) If it does appear to be a scam though then eBay needs to know about it.
Good luck.
Olezippi,
Good luck.
Thanks man. I was able to contact the seller.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
That horn on Flebay has sold. Still on the search for a good working 47 thru 53 horn.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Moderator
Moderator
2 Offline
I'm pretty sure I have what you are looking for on a 48 1-1/2 ton.
I'll check it today and then PM you if I do.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Moderator
Moderator
2 Offline
Is one of these what you are looking for.
The price will sound way high BUT, you have to take the complete truck with it!
PM me and we'll see if we can work something out.
Don
"The Flag Pole"
1953 1-ton pickup
2-Ton #1348459 03/01/2020 7:43 PM
Thanks for all the replays fellows. I have a horn on the way.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
I watch a youtube post called goonzquad and they installed a semi horn and they had to move the spare to have room to install it under the truck.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Crusing in the Passing Lane
2ton, red truck looks nice.
Ed
Moderator
Moderator
2 Offline
Well Ed, I guess I like the color red!
I even married a Redhead!
Good to hear Ole that you found the one you wanted.
Don
"The Flag Pole"
1953 1-ton pickup
Congrats on obtaining your new Horn....
Another quality post.
Real Trucks Rattle
