1 members (Otto Skorzeny),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | I was surfing around looking at various posts and saw a comment that the old GMC engines were better than the Chevy engines. Can someone pls. enlighten this newbie on this?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | When GMC introduced their own OHV 6-cylinder engine in (1939?) it had insert type rod bearings with oil pressure to the rods, while Chevy still had the babbitted rods and the dipper/ nozzle/ trough oiling of the rods. Some say everything about the GMC engines were built more heavy duty. They were “truck” engines.
Professional Novice
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Pontiac engines were available in GMC trucks from 1955 onwards (New Design GMC trucks)older GMC engines (1955 Z-series and earlier) GMC trucks: GMC 228, 248, 279, 302 (6-cylinder engines) were not Pontiac engines. [/quote] And to add to that: in 1960 the standard engine in the pickups was the GMC 305 V6, this was not a pontiac engine, and believe from 1960 and up never another pontiac engine came down the line in a GMC, although later they offered chevrolet engines in GMCs
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | And don't forget about the Buick Nailhead engines in some of the GMC big trucks from '57-'59.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I was surfing around looking at various posts and saw a comment that the old GMC engines were better than the Chevy engines. Can someone pls. enlighten this newbie on this?
Thanks I believe the assertion of "better" is from the pressurized oiling in earlier GMC's as Frank stated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That would be “higher pressure” oil system in earlier GMC 6 cylinder engines?
Even low-pressure Chevrolet engines had/have pressurized oil lubrication systems.
I think I have heard/read that the GMC blocks and heads were harder (more zinc, maybe). If so, they were harder metal.
It is late, and I have had a few wee drams. Forgive me. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | GMC sixes were designed to be rebuilt multiple times. The pickup and midsize truck engines benefited from the same design features as the big rig engines- - - - -some of those engines even had cylinder assemblies that were separate from the crankcase, such as the 503 cubic inch inline six used in the mid-1950's heavy duty trucks. For instance, GMV 228-302 connecting rods have full-floating wrist pin bushings and lock rings in the pistons to retain the pins- - - -Chevy uses a clamp bolt in the rod to lock the pin to the rod. GMC oil pumps are huge compared to Chevy pumps, and the GMC runs approximately twice as much oil pressure. GMC has a much better cylinder head design- - - - -and the list goes on and on! Jerry
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | And don't forget about the Buick Nailhead engines in some of the GMC big trucks from '57-'59. Carl, Chevrolet used the Buick Nailhead (while they developed the 348), not GMC... Mike B  | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | In the early 1930's GMC used Pontiac and Buick engines im their smaller trucks and Knight sleeve-valve engines in the bigger rigs. A few of their off-road rigs used for mining and dam construction projects had engines that displaced 700+ cubic inches. Pontiac and Oldsmobile V8's were used in some applications in the mid-1950's. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC big trucks even had Olds 370 engines in '50's trucks.
Ed
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | GMC has an interesting history as it started outside of GM. By the 30s they used engines from other GM divisions including Oldsmobile and Pontiac. YouTube video
Professional Novice
