Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Guitplayer, Hush), 106 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#1347058 02/18/2020 7:22 PM
Has anyone used a 85 K-10 Tilt column in a 56 3100 half ton pickup. I have one an wondered if its a good swap for my truck
I have a 1984 tilt column in my 49 and it works well.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
We probably need more information on what you are trying to accomplish. Be aware that the 56 column is attached to the steering box as an assembly. If you plan on installing power steering because the steering box is worn out it may be a way to go. If you have the original column shifted transmission, a floor shift of some kind would likely be required. If you are changing to an auto trans just about any later model or aftermarket column can be used with some modifications.
Fred
