7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC),
60
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I'm thinking about putting vintage air in my 59 truck. Sales guy tells me I should update charging system from my 1982 chevy internal regulated alternator to some crazy 162 amp alternator, so I can have an electric cooling fan for the radiator. I think a 162 amp alt is a little much. Wouldn't that over charge the battery and boil the battery dry?
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | “Sales Guy” enough said!ðŸ›
| | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | What Martin said. But to answer your question, the alternator regulator would keep the battery from overcharging, even with the higher amp output capability.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Can the sales guy visit my place and talk to my garden? Fertilizer is expensive, and he's spreading it on thick! Jerry
| | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | Tommy just as a point of reference, I have an Old Air AC in my 59, using a belt driven 6 blade flex fan with shroud, and have no overheating problems driving many miles in 100+ degrees Oklahoma days. My ordinary 3-wire alternator works fine to keep up with everything, I think it is less than 60 amp output. Your alternator should be fine if you have a good engine driven fan system.
Mark | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I called it B.S. from the get go, chevy vehicles had a/c ,p/w all sorts of electrical options and never had an alt. that big. As for the electric fan, I don't like them. I have a 261 engine in my truck and have no heat related problems living in south Louisiana in the summer, so I don't think the a/c would be a problem. Thanks,all.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Hmmmm- - - - - -if electric motor driven fans are all that wonderful, why don't airplanes use 'em to turn the propeller? LOL! Jerry
| | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | Actually there are now some airplanes with electric motors, powered by batteries. Real planes, not drones.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
