4 members (baldeagle, 78buckshot, JW51, moparguy), 83 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1347818 02/25/2020 12:34 AM
I'm thinking about putting vintage air in my 59 truck. Sales guy tells me I should update charging system from my 1982 chevy internal regulated alternator to some crazy 162 amp alternator, so I can have an electric cooling fan for the radiator. I think a 162 amp alt is a little much. Wouldn't that over charge the battery and boil the battery dry?
Tommy
59 apache 1/2t
261 short stepside
Tommy #1347821 02/25/2020 12:51 AM
“Sales Guy” enough said!🛠
What Martin said. But to answer your question, the alternator regulator would keep the battery from overcharging, even with the higher amp output capability.
Can the sales guy visit my place and talk to my garden? Fertilizer is expensive, and he's spreading it on thick!
Tommy just as a point of reference, I have an Old Air AC in my 59, using a belt driven 6 blade flex fan with shroud, and have no overheating problems driving many miles in 100+ degrees Oklahoma days. My ordinary 3-wire alternator works fine to keep up with everything, I think it is less than 60 amp output. Your alternator should be fine if you have a good engine driven fan system.
Mark
Tommy #1347859 02/25/2020 11:18 AM
I called it B.S. from the get go, chevy vehicles had a/c ,p/w all sorts of electrical options and never had an alt. that big. As for the electric fan, I don't like them. I have a 261 engine in my truck and have no heat related problems living in south Louisiana in the summer, so I don't think the a/c would be a problem.
Thanks,all.
Tommy
59 apache 1/2t
261 short stepside
Hmmmm- - - - - -if electric motor driven fans are all that wonderful, why don't airplanes use 'em to turn the propeller?
LOL!
Actually there are now some airplanes with electric motors, powered by batteries. Real planes, not drones.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Crop dusters?
