0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2019 Posts: 9 New Guy | | New Guy Joined: Jun 2019 Posts: 9 | New to me pickup that's had some nice upgrades done to it (90's era 350 and a 200R4 auto transmission, 3.73 rear-end). Before summer, I want to take care of a couple things. First, there's only one lock on the doors and I don't have the right key. I saw a set of 2 door locks, ignition & glovebox with matching keys. Is that the best option for me? I think I can follow the tutorials here. Second, there's a couple things on the transmission: the speedo is WAY off, so I'm thinking a new speedo gear might be a way to go but I have no idea how to figure what I need! Any advice would be wonderful. Thanks! [img] https://photos.app.goo.gl/YFftRjbf5g2G4F7j9[/img] | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Just do a search on speedometer gear calculator and a number of sites will come up. They have a chart where you plug in the transmission, rear gear, and tire size which then gives the speedometer drive and driven gear combo needed.
Evan
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | ratio calculator to be used by a shop that makes/sells ratio adapters I always use the one at the bottom of that page. There are speedometer companies that make the adapter to your spec/need. | | | | | Joined: Jun 2019 Posts: 9 New Guy | | New Guy Joined: Jun 2019 Posts: 9 | | | | | | Joined: Sep 2019 Posts: 35 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 35 | As far as your door locks, you have a couple options. You can do what you mentioned above, or you can take your current drivers lock out only since this should be the one with the key hole. Take it to a locksmith and they should be able to cut you a new key with no problem and ask for a spare key. You can actually lock the passenger door without a key, (only from the inside). Just reach across and pull the door handle up and it locks the door. Then when you get the key to fit your driver's door, close and lock it with the key, then your truck is locked up.
Good luck.
| | | | | Joined: Jun 2019 Posts: 9 New Guy | | New Guy Joined: Jun 2019 Posts: 9 | As far as your door locks, you have a couple options. You can do what you mentioned above, or you can take your current drivers lock out only since this should be the one with the key hole. Take it to a locksmith and they should be able to cut you a new key with no problem and ask for a spare key. You can actually lock the passenger door without a key, (only from the inside). Just reach across and pull the door handle up and it locks the door. Then when you get the key to fit your driver's door, close and lock it with the key, then your truck is locked up.
Good luck. It's funny...the only key hole is on the passenger side on my truck! And I figured if I get in there, I might as well do both sides. I knew about locking from the inside but thought it would be good to have both sides unlock-able from outside. Now, to fix the vent window on the driver's door so someone can't just reach inside to open the door! | | | | | Joined: Sep 2019 Posts: 35 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 35 | Very true, busted wing window = easy unlock. Precision brand weatherstrip worked good for me. Them or trim parts i think are the better brands in my opinion. Precision has non glue on weatherstripping for the doors, they have a metal piece that taps over over the pinch weld. No glue, no mess... Took about 10 min to put both sides on. | | |
