4 members (Paul_WNC, Otto Skorzeny, Rusty Heaps, dunfire), 82 guests, and 1 robot.
Topics128,050
Posts1,055,644
#1347287 02/20/2020 7:30 PM
Ive got a 1947 GMC 300, is the front axle the same as the 1 ton?
For example can i just order new front spindles for a one ton and install them so i can have an 8 lug bolt patttern or is there more to it than that?
Logan
2010 Silverado 2500HD
1947 GMC 300
Crusing in the Passing Lane
What bolt pattern do you have now?
Ed
its a 5 lug, im afraid i dont know the spacing. i just dont want to have to find a whole axle if its not necessary
Logan
1947 GMC 300
Is the front axle 5 bolts and the rear 10, if so that setup is usually called 5/10 on 7.25" bolt circle, measure across bolts on rear to get diameter.
Ed
5 lug front an rear. The actual axle looks normal size and something that would be on a half and 3/4 ton but im not sure
Logan
1947 GMC 300
