1 members (baldeagle),
145
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Ive got a 1947 GMC 300, is the front axle the same as the 1 ton? For example can i just order new front spindles for a one ton and install them so i can have an 8 lug bolt patttern or is there more to it than that?
Logan 2010 Silverado 2500HD 1947 GMC 300
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What bolt pattern do you have now?
Ed
| | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | its a 5 lug, im afraid i dont know the spacing. i just dont want to have to find a whole axle if its not necessary
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Is the front axle 5 bolts and the rear 10, if so that setup is usually called 5/10 on 7.25" bolt circle, measure across bolts on rear to get diameter.
Ed
| | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | 5 lug front an rear. The actual axle looks normal size and something that would be on a half and 3/4 ton but im not sure
