1 members (Steve_H), 186 guests, and 1 robot.
Topics128,162
Posts1,056,934
Members48,458
#1347038 02/18/2020 5:18 PM
New tires and rims installed. Also14 bolt rear axle. [img]http://[/img]
Rustbucket Ranch
Rustbucket Ranch
Looking good! I really like those wheels
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
John,
What size rims are they? They do look nice! More so, I bet, a nice smooth ride.
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
They are 19.5's They are pretty smooth and I think the ride will be even better once the bed is completed and installed.
9
9 Offline
What did you do about the stud size on the front?
Did you use a flange,conical or shank lug nut?
55 250 8 GMC Flatbed
67 M715
69 CJ5
72 M35A2 Bobbed
75 CJ6
80 K3500 Flatbed
95 XLC2
71 C30 Flat Bed
Drilled the hubs for larger studs and went with metric studs front and rear so I could use the GM center caps. I am using latter model plates on the front and 60 degree conical nuts on the rear.The reason for that was on the rear the aluminum rims are so thick plus the thickness
of the plates the studs were to short. I tried to find longer studs but couldn't find any.
That does look nice.
ppp
Moderated by  Dusty53
