Topics128,139
Posts1,056,448
Members48,441
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
New tires and rims installed. Also14 bolt rear axle. [img]http://[/img]
Rustbucket Ranch
Rustbucket Ranch
Looking good! I really like those wheels
John, What size rims are they? They do look nice! More so, I bet, a nice smooth ride. Jim
They are 19.5's They are pretty smooth and I think the ride will be even better once the bed is completed and installed.
What did you do about the stud size on the front? Did you use a flange,conical or shank lug nut?
55 250 8 GMC Flatbed 67 M715 69 CJ5 72 M35A2 Bobbed 75 CJ6 80 K3500 Flatbed 95 XLC2 71 C30 Flat Bed
Drilled the hubs for larger studs and went with metric studs front and rear so I could use the GM center caps. I am using latter model plates on the front and 60 degree conical nuts on the rear.The reason for that was on the rear the aluminum rims are so thick plus the thickness of the plates the studs were to short. I tried to find longer studs but couldn't find any.
ppp
