| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 3 New Guy | | New Guy Joined: Feb 2020 Posts: 3 | I have a '62 C60 and I'm having to replace the head. I have a question about the mold numbers. Is this a good place to ask it? Sorry never done the forum thing before. | | | | | Joined: Feb 2020 Posts: 3 New Guy | | New Guy Joined: Feb 2020 Posts: 3 | Did you ever find out what the GM-5 means? I have same mold buy mine says GM-4. I think I found a replacement but it says GM-5. And trying to see if that makes a difference. TIA | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | GM5. That is the mold (also called pattern) number to identify it in case of a problem with a casting. There were several molds for same block/head. Several foundrys. Determine application by the casting number/part number and date codes.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Welcome to the Stovebolt  Are you working on a 6-cylinder or V8? Mike B
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Did you ever find out what the GM-5 means? I have same mold buy mine says GM-4. I think I found a replacement but it says GM-5. And trying to see if that makes a difference. TIA So you knew it was a mold number? or did you change your post?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | There’s been some moderatin (not me) going on.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I'm kind of lost. Can't remember if he already knew, which means I am losing it. I was thinking he wanted to know what the GM5 was. I didn't notice he had already called it a mold number. If someone has changed the original two posts, that was a bad idea. If they have not been changed, then I need medicine.
