5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1346854 02/17/2020 4:18 PM
I have a '62 C60 and I'm having to replace the head. I have a question about the mold numbers. Is this a good place to ask it? Sorry never done the forum thing before.
Did you ever find out what the GM-5 means? I have same mold buy mine says GM-4. I think I found a replacement but it says GM-5. And trying to see if that makes a difference. TIA
Sir Searchalot
Sir Searchalot
GM5. That is the mold (also called pattern) number to identify it in case of a problem with a casting. There were several molds for same block/head. Several foundrys. Determine application by the casting number/part number and date codes.
Welcome to the Stovebolt wave
Are you working on a 6-cylinder or V8?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
So you knew it was a mold number? or did you change your post?
There’s been some moderatin (not me) going on. chug
Sir Searchalot
Sir Searchalot
I'm kind of lost. Can't remember if he already knew, which means I am losing it. I was thinking he wanted to know what the GM5 was. I didn't notice he had already called it a mold number. If someone has changed the original two posts, that was a bad idea.
If they have not been changed, then I need medicine.
