8 members (GA Boy, 2-Ton, Gray_Ghost, Nick in Manitou, GMCJammer51, Joe H, Andrew_Julio, Jay R),
75
Mod | | | Forums66 Topics128,169 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, I have a question. What is the need for the cover to which the arrow points? Look here: https://www.kripahle-online.de/unterricht/?page_id=2408I ask this question cause I've forgot to screw on the housing befor I fix it to the engine block. Is it absolute nessesary to fix this cover to the gear housing? Ask Wolfgang | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The world won't end if you leave that cover off, access port, keeps dirtout. Can fix it later, preferably before mounting in chassis, might not have access without removing floorboards/tin from inside of vehicle.
Ed
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Unless you're doing a lot of driving in muddy off road conditions, there shouldn't be any problem with the cover being missing. Jerry
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | It’d take you 5 minutes to make one with some snips and some 18 or 20 gauge sheet metal and a drill.
