5 members (Jay R, Hanks custodian, Nick in Manitou, Phak1, Wayne67vert), 113 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#1346499 02/14/2020 4:58 PM
is there anyone that can give please me some ideas on how to go to get a bumper on my 46 Pick up ?
I bought a new bumper for the front which means I was thinking of losing the custom bumper I have tight under my tailgate and going back closer to the factory bumper . I’m guessing front and rear bumpers in these trucks was the same, so I should be sble to use it on the rear.
I bought 1946 bumper irons but my frame has been boxed and a box section crossmember has been added to the chassis at the very rear. This probably counts out using the original style brackets.
My question is is there other years bumper brackets that would work ? Also would the bed parts and bumpers from later models fit my bed? The beds on later years look the same so would the bumper and step panels , lower body panels etc also work in a 42-46 Truck?
Thanks in advance for any help
Regards
Chris
I attached a couple of photo's of the original attachment. You could cut them and weld the brackets to the boxed end channel or you could drill or grind through the boxed end large enough to insert the OME brackets to the frame? All depends what you are dealing with. Good Luck.
Ah that’s how they go ! They go the other way up to how I was trying to fit them. They are suppose to slip on the inside of the c channel of the frame 🤯A picture paints a million words . Thanks for that .
I doubt very much if I can fit them like this with my frame boxed and a box section crossmember added to the rear of the chassis. This will help me locate where the bumper is supposed to be.
Does anyone know if a later model bumper will fit easier or be easier to adapt ? Or will I just have to get something custom made?
