| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13458 11/17/2001 9:17 PM | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | The oil pressure gauge for gmc's of the same years will fit my '53 chevy, and have a larger range on the oil pressure right? Does it go up to 60lbs? I'm going to be using a 350, what do they normally run at?
'53 Chevy truck 1/2 ton
#13459 11/19/2001 6:49 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Kevmor99,
All the '47-'53 GMC clusters I've seen had a 0-80# oil pressure gauge, same style as the Chevy, but had red numbers on a cream-colored face.
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#13460 11/20/2001 1:34 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Chevy 216 was 0-30. 350's usually run 35 lbs warm. All the GMC gauges I've seen went to 60.
