6 members (Otto Skorzeny, greenie-reddy, mick53, dt235sd, DadsFirstPickup, 5 Window 9434), 72 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
The oil pressure gauge for gmc's of the same years will fit my '53 chevy, and have a larger range on the oil pressure right? Does it go up to 60lbs? I'm going to be using a 350, what do they normally run at?
'53 Chevy truck 1/2 ton
Kevmor99,
All the '47-'53 GMC clusters I've seen had a 0-80# oil pressure gauge, same style as the Chevy, but had red numbers on a cream-colored face.
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Chevy 216 was 0-30. 350's usually run 35 lbs warm. All the GMC gauges I've seen went to 60.
Paint & Body Shop moderator
