0 members (), 91 guests, and 1 robot.
Topics128,055
Posts1,055,782
#134582 06/27/2006 8:57 PM
Junior Member
Junior Member
just a dumb Question.... I've got a 55 gmc sub. sitting on a 74 chyenne 1/2 ton frame w/454 and turbo400. I don't have the radiator from the 74 but do have the one from 55 V-8 (orig. but been restored) do I need cross flow or does orig. cool it?I have a tranny cooler and oil cooler.
#134583 06/27/2006 9:09 PM
Have the original re-cored at the local radiator shop. The flow does not really make any difference in cooling capacity, a cross flow is easier to use with a low hood line. You can tell the rad shop what size engine you are running, they will be able to re-core it to handle it. You will be able to keep the original mounting that way.
Bill Burmeister
#134584 06/30/2006 7:30 PM
Junior Member
Junior Member
Thanks bill, running a 454, so I'll talk to radiator guy O.
