1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#134523 06/12/2006 10:46 PM
Junior Member
Junior Member
I am putting a v-8 in my 48 1/2 ton got a after
market crossmember for motor mounts. do you have
to cut this to fit inside frame rails? Thanks
for any Help!
#134524 06/12/2006 11:50 PM
If it is a universal one, yes, the tubing should be longer on each side. Center in frame at the proper height and tach it in place. Some come with flanges that you weld to the crossmember and then can be bolted to the frame. Just do not weld it solid untill you mock up the entire drivetrain and are sure everything is where it is supposed to be. Good luck......................
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
#134525 06/12/2006 11:59 PM
Junior Member
Junior Member
Thanks Dale mine did come with the flanges!
#134526 06/13/2006 4:47 AM
You need to figure your driveline angle before you mount your crossmember. It may bolt under the frame, not between the rails. It may need shims.
