| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Hello all,
I have a 57 Chevy 1/2 ton 3 on tree, stock steering column. My question is will a 55-56 steering wheel work on my truck?
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It will fit the shaft and bolt on. But, the 57-59 column is 4" shorter than the 55-56. The 57 wheel is dished whereas the 56 wheel is flat. Also, the shift lever on the 57 has more of an angle to match the wheel. Fred
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Like Fred said the simple answer is NO it won't work. The turn signal lever will also hit the wheel and if I remember correctly the top of the wheel gets very close to touching the top of the dash. Mike B  | | |
