1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1344938 02/04/2020 5:38 AM
Hello all,
I have a 57 Chevy 1/2 ton 3 on tree, stock steering column. My question is will a 55-56 steering wheel work on my truck?
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
It will fit the shaft and bolt on. But, the 57-59 column is 4" shorter than the 55-56. The 57 wheel is dished whereas the 56 wheel is flat.
Also, the shift lever on the 57 has more of an angle to match the wheel.
Fred
Like Fred said the simple answer is NO it won't work. The turn signal lever will also hit the wheel and if I remember correctly the top of the wheel gets very close to touching the top of the dash.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
