6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#1344798 02/03/2020 1:02 PM
I’d like to replace the worn out wire wheel on my vintage Black & Decker Type K bench grinder with one close to identical. The hole is large and it has more wire in it than I’ve ever seen! It has to be made for industrial use because it’s heavy and really well made. It is imprinted with “Masterwheel” and a patent #. Never have seen this type at the big box stores so wondered if you guys could tell me where I can go to buy one like it? Thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Check this site and contact the moderator. He may be able to help.
Harold
http://vintagemachinery.org/mfgindex/detail.aspx?id=101&tab=4
Harold
AD Addict & Tinkerer
Normally, the wheel is sized by the arbor size of the grinder. Did you remove any adaptor collar from the center of the wire wheel?
Finer wheels have more wires that coarse wheels and better quality wheels have more wires also.
Phil
Project Journals
Stovebolt Gallery Forum
Harold, thanks for the link. I’ll reach out to the moderator.
Phil, yes, there was a very large adapter that fit the hole in the wire wheel. The arbor size was larger than usual and I can’t remember what size wrench I used to take off the retaining nut. I might be able to find a new wheel that has the same size hole as the diameter of the arbor. That’s probably an option if I can’t find one like I’m trying to replace.
Chuck
1941 Chevy coupe
Check the local yellow page edition locally for "Industrial Supply House and/or Abrasive Supplies. I haven't been to them but I have heard many comments about two that are located just 20 miles from me............and a GOOD wire brush is of a necessity from a stand point of our hobby and safety.
......keep us posted on your findings. I'm sure many here, including myself that would like to know. (I use an 8" brush)
You can shop around on McMaster, too.
MNSmith #1344877 02/04/2020 12:00 AM
McMaster has a variety of wire wheels with 1", 1-1/4" and 2" arbor holes. I'm guessing your old wheel is one of those.
I just checked MSC and they also have wire wheels with 2" arbors.
SimS
Thanks for the tip about McMaster. I’ll look there first, then Google industrial supply houses here in San Antonio as a local option. Surely some place here has what I’m looking for.
Chuck
1941 Chevy coupe
Moderated by  MNSmith
