5 members (MickeyP, papas52, dt235sd, GA Boy, dgrinnan), 76 guests, and 1 robot.
Topics128,169
Posts1,057,035
Members48,458
#1344351 01/30/2020 11:36 PM
My cousin recently purchased a 57 3100 Chevrolet pick up here is a picture of the Vin from title want to decode this with as much information as possible
Brian.
1952 GMC model 473 dump truck
1951 Chevy 1500 stepside
Truck is in very good shape.
New 350 engine
New interior
Body 99% perfect
Needs new tires and wheels
Brakes all new
Needs new wooden floor in bed
Needs gas tank under bed.
Truck runs excellent.
Prefix on title says 20?
Here ya go!
3B = 3200 1/2 ton Long Bed (123" wheel base)
57 = year
B = Baltimore Plant
109239 = unit number starting with 100001, making it the 9,239th unit built in Baltimore
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
Prefix could be the number of previous owners. Call the DMV.
Thank you Mike B!
Thanks. Bartamos!
Brian
How do I find out original motor/trans?
Former Workshop Owner
You are wanting to know whether it came with a 283 V8 or 235 six? I'm sure the answer is in the archives somewhere here on the "Bolt".
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
This might help.
Vehicle Information Kits
1957 Chevrolet truck info kit
The 350 is not the original engine.
The vehicle serial number (3B 57B 109239) 3B would have a "V" added if the truck came with a V8 engine.
There were only two engines available for your 3200...the 235 6-cylinder and the optional 265 V8. The 261, 283 and 322 were all big truck engines in 1957. Since your Serial Number doesn't have a "V" prefix, it was not born with a V8 engine, so it had the 235. The front cross member V8 motor mount brackets were riveted on at the factory and the aftermarket brackets are bolted on, another way to tell if it was born a V8...
The 3 on the tree 3-speed was the standard issue trans with the HD 3-speed (with floor shifter) and the Hydromatic as options. Look at the floor board just above the steering column and see if there is a hole in the floor that the column linkage went through...if there's a hole it was born with a 3 on the tree or the Hydromatic. Now look to see if it had a clutch pedal hole...if both of these are yes, than it had the standard 3-speed.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
This has a lot of 1957 Chevrolet truck information.
1955-1959 Chevrolet Truck Factory Assembly Manual PDF
Sir Searchalot
Sir Searchalot
Originally Posted by Brian_Ostner
Thank you Mike B!
Thanks. Bartamos!
Brian
You are welcome. A thank you is always nice and appreciated.
