| | | Forums66 Topics128,142 Posts1,056,476 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Does anyone have a part number or vendor for the metal gasket on a 46 1.5T rear axle hub? Both sides are leaking.
Thanks | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | I think you are talking about the gasket between the hub and axle shaft, if the metal is in good shape I would clean all mating surfaces with brake cleaner and use some non-hardening gasket sealer with the original gaskets. Mine were not metal, I made new ones with a medium weight gasket material.
| | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Thank you, I've considered that as well. I have the gasket material to make them, however was curious if new were available. | | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | The best axle "gaskets" are soft metal, either copper or aluminum, and need to be coated with a non-hardening gasket sealer. If there is any movement at all between the axle and the hub, even a few thousandths, a paper gasket will be damaged and start leaking. Bigger full-floater rear hubs have tapered metal cones that grip the bolts tightly and fit into corresponding tapered holes in the axle flange to prevent any movement. 3/4 and 1 ton rear axles usually don't have them, but the OEM bolts have an unthreaded shank under the head that's a very close fit to the holes in the flange. Jerry
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | The original "gasket" on comparable generation 1940-45 military trucks was a malleable lead and tin terne-plate material. If assembled with a non-hardening cement, they seal pretty well. I have sources for the military style axle gasket. Do you have measurements from your gasket...maybe they are the same? | | |
